Replacing thermostat 4 wire to 5 wire. Help!!!
Old 01-26-09, 06:54 PM
B
Question Replacing thermostat 4 wire to 5 wire. Help!!!
Hello,
I am replacing an old White-Rodgers 1F56-310 thermostat with a new (somewhat unknown brand) TotalLine TotalTouch P286-1500. I have included the links to the manuals for these thermostats.
The problem is that the new one requires 5 wires, whereas the old one only used 4. Unfortunately I only have 4 wires going from my furnace to the thermostat. Any suggestions on how I can avoid pulling a new wire?
Here is how the old thermostat was wired:
Red went to RH and RC (which are also shorted by a jumper)
Green went to G
White went to W
Blue went to Y
According to the manual of the new thermostat I need to connect:
24V (Red) to RH
Fan (Green) to G
Heat (White) to W2
AC (Yellow) to Y1
and Common (Blue) to C.
It is that Common wire that I am missing... I tried attaching everything except for that missing wire but the heat/cool options in the thermostat did not activate. No surprise, because according to their help (link attached), if one has a gas furnace, the Common wire MUST BE CONNECTED.
I have a gas furnace and an AC - pretty simple setup. Can I do anything to get this thermostat to work? Pulling a new wire does not seem like an easy task...
Thank you!
Old 01-26-09, 09:11 PM
R
You should asking this in the heating forum. But than likely the "C" terminal is like the jumper wire on your old thermostat. In the new themostat a wire is connected from the RH terminal to the C terminal.
Old 02-04-09, 08:05 PM
F
Received 36 Votes on 28 Posts
I see that Bbyaka did go to the heating forum and get his thermostat wired but I wanted to address this for anyone that may stumble on this posting.
That is absolutely WRONG and will either blow the control fuse in the furnace (if a fuse is present) or burn out the control transformer.
