Question about lowering electric bill: Windows or OnDemand Water Heater?
I have a 1928 rowhome which is located in the middle of the row. There are 9 windows ranging from 2 wooden single pane windows, 1 metal single pane window, 1 small window which has the glass slats that close, and 5 very old vynil dual pane windows.
My house has natural gas, uses a boiler and radiators for heating and window air conditioner units (1 12,000 BTU window unit for 1st floor, 13000 BTU portable unit for basement, 2 6,000 BTU for the bedrooms) it has 2 bedrooms, 1bath and is 3 stories (including basement)
I like cold better than hot, and my electric bill is always more in the summer. I keep the A/C anywhere b/t 60-65 and same with the heat.
My question is will I see more savings by replacing all windows with a better, more efficient dual pane window or by replacing the water heater (fairly new 40 G tank - natural gas) with something like the Rheem Tankless Water Heater RTG-53PVN. I do like to take showers, and I am the only one living here (i do tend to take long showers -- until the water runs cold).
Thanks for your input, please feel free to ask for more specifics.
So you have 4 single pane and 5 dual-pane windows. What si wrong with the dual pane vinyl ones? Are they warped, ill-fitting, felt worn off of the sides, ?.
After reading in your post that you'd rather be cold than hot, I thought that if you took cooler showers instead.......
Changing all the windows would pay for themselves in very short order for both heating and cooling.
