Hunter Thermostat 44155c
Old 02-25-10, 05:06 PM
C
We just recently installed a new Hunter thermostat 44155c on our gas furnace. It worked fine the fist few days. Now when I get home from work it is 60 degrees in the house and the fan is blowing but there is no heat. I shut it off for 15 minutes and turn it back on and it works again. Then the same thing the next day. I turn the heat down before I leave in the morning. We had it programed but that was the problem and now we are using it manually and it is still messing up. Any suggestions?
Old 02-25-10, 06:17 PM
G
Received 2 Upvotes on 2 Posts
First, make sure the fan switch is set to auto.
Old 02-26-10, 04:24 AM
C
It is set to auto. This morning when we woke up it was 53 degrees. Thats pretty cold when it's only 19 outside!
Old 02-26-10, 04:53 AM
B
Received 47 Upvotes on 43 Posts
Hi cassmarie and welcome to the forum.
I'm not a heating pro, but some basics may help.
If it worked for a few days and now will not work even in manual mode, I would first replace the batteries. If it was wired wrong, it would not have worked in the first place. If that does not help, Hunter has 1-800 number to call for support, then I would take it back and ask for a new one.
The pros may have something additional.
Bud
