Crawl Space
I recently purchased a home and the home has hot water heat. the pipes aren't insulated neither is the floor. I in the process of insulating the floor and the hot water pipes and installing a vapor barrier. Should i close the vent during the winter months and is it ok to insulate the water lines.
Received 6 Upvotes
Hi:tommym
In my opinion, it's always a good idea to insulate the hot water pipes and install a vapor barrier. Not a good idea to close the under house air vents.
In regards to closing any under house air flow ventilation vents, read the prior posting topic called "close vents" asked by FontanaHorseman.
In that posted topic, you'll have two opposite opinons posted. The information posted may help you decide which to do. Leave them opened or close them.
You may also want to check back further into the archives, in this forum, for more opinions on the subject of closing underhouse air vents.
