Holy Caulk, Weatherstripping, Foam batman... (help!)
Old 01-08-14, 08:52 AM
B
Alright guys, I'm a bit overwhelmed with what is best here - so let me explain and provide some pictures.
Overall problem: My main room - family room/kitchen combo - has a really hard time retaining heat. There are cold drafts in the winter and the room is considerably colder than other rooms. It's pretty much a full wall of windows, a sliding glass door, and exposed brick... so there are more than one problem areas. I'm a novice here, but here's what I've determined those areas to be.
Problem #1: Gap between floorboard (wood) and wall (exposed brick). I currently have this partially stuffed with steel wool (mice) but definitely feel air coming in.
Solution #1: Caulk? Foam? Weatherstrip foam stuffed in there?
Problem #2: Above that same area, the exposed brick meets wood molding under the windows. There are gaps there as well, which as you can see I tried to fill with foam and made a mess.
Solution #2: Caulk? Foam? Weatherstrip foam stuffed in there?
Problem #3: Under sliding glass doors, there's a gap between the floorboard (wood) and the shoe molding (wood).
Solution #3: Caulk? Foam? Weatherstrip foam stuffed in there?
Problem #4: Above sliding glass doors, the brick has receded leaving a gap between that and the wood paneling. There's flashing on the underside where the brick meets the wood.
Solution #4: Caulk? Foam? Weatherstrip foam stuffed in there?
Thanks so much!
Old 01-08-14, 09:18 AM
Received 403 Votes on 359 Posts
The expanding foam does a better job of insulating but caulking does a neater looking job. I'd cut out any of the excess foam and use a clear siliconized acrylic latex caulk on most of it. Can you nail the shoe moulding any closer to the floor before you caulk it?
Heavy drapes over the windows will help some.
