Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Energy Usage, Conservation and Weather Stripping
Reload this Page >
Best cost effective way to insulate windows and how to save heat.
Old 10-05-14, 08:46 AM
Hello,
I am trying to get ready for winter.
my windows really do not have the solid frames all around to use the plastic to cover it, and I heard mix review about those. I also Heard a lot of people use drapes. I wanted to which way actually works in most situation? maybe something all around so i do not have to keep changing it.
Thanks
Old 10-05-14, 11:38 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
What type windows do you have? Single pane, thermopane, LoE? Maybe posting a few pictures of the windows would help us give you better advice. http://www.doityourself.com/forum/el...your-post.html
Old 10-05-14, 03:53 PM
Size:  11.0 KBName:  20141005_170454.jpg
Size:  12.1 KBName:  20141005_170445.jpg
I think it will be very difficult putting the clear film
Old 10-05-14, 05:53 PM
chandler's Avatar
Well, that went well. Pictures of shades, not windows. Difficult to tell what type windows you have. From what I can see, you have wooden frames. Can you raise the shades and let us see how the windows are put together?
Old 10-05-14, 06:30 PM
Received 1 Upvote on 1 Post
Tired of messing with plastic, install replacement windows or storm windows.
The heat shrink plastic gets attached to the window casings and apron under the window, not the window it's self.
Works fine just a pain to have to install and uninstall every year and have to deal with the paint it peals off.
Old 10-05-14, 07:14 PM
Size:  17.0 KBName:  20141005_220817.jpg
Size:  20.2 KBName:  20141005_220726.jpg
Here are some more picture. Wonder if their is something as effective as the plastic film. Really hate to keep putting them on and off yearly. Just isnt worth the time, I think.
Old 10-05-14, 09:15 PM
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
Well, you have a few options. Replace the windows, install exterior or interior storms, or use film. Of course if you are renting, nothing permanent would be allowed I'm sure.
Heavy drapes would be an option, but that eliminates any light.
Old 10-06-14, 03:02 AM
chandler's Avatar
It appears you have storm windows anyway. Are they sealed well from the outside, except for the weep holes? Do they operate properly?
Old 10-06-14, 11:09 AM
Received 1,197 Upvotes on 1,152 Posts
Plastic works well, so can drapes. After that I'd be looking at new windows.
Old 10-06-14, 01:22 PM
I have drapes on most of the windows. I was quoted over 10k to replace my 16 windows. Can not do that now. Whats the best way to utilize the drapes? at night I close them all around and move them aside in morning so sunlight can get in.
Old 10-06-14, 01:35 PM
chandler's Avatar
Close the drapes when it is cold outside, or when sunshine threatens the coolness of the interior of the house. Open them when sunshine is needed to warm the house up. Replacement windows are very DIY friendly. Can you search locally for windows only? You can do the labor yourself, or with a friend. We can walk you through it.
Old 10-06-14, 01:59 PM
You have some video links I can watch? to get a good idea of how its done?
Old 10-06-14, 02:18 PM
Last year was the only time My Pepco bill went upto $500, Due to the fact our ac had issue and we did not know that.lol. But it usually about $150-200 in winter time. We are usually at work or outside of the most of the time.
Old 10-06-14, 02:27 PM
And its a 3 bedroom with 2 upper floor and one basement.
Old 10-22-14, 08:26 AM
doublezero's Avatar
Received 2 Upvotes on 2 Posts
Which tape should be used to tape the plastic sheeting to the windows? All the tape I have used in the past either isn't sticky enough, or it's too sticky so it rips off the paint when I remove it. Another consideration is what the tape looks like. I have rentals, so I don't want to use Tuck Tape and have the units look like a construction site. Tenants don't like that...
Old 10-22-14, 11:14 AM
I've always used the tape that came with the plastic - I've only used the 3M kits.
Old 10-22-14, 11:53 AM
lawrosa's Avatar
Super Moderator
Received 79 Upvotes on 71 Posts
From my experience the windows are OK and you have storm windows already.
1. Are there seals where the windows touch the top and bottom? If not add some type of weather seal..
2. Always lock the windows in winter. It makes them tight and seal better. especially where the lock is.
3. I bet you 2 shillings that if you pull the trim moldings from around the windows I would be certain there is no insulation or minimal/ Get some insulation and stuff it in the cracks...
4. As chandler stated caulk around the outside of the storm windows.
5. Make sure the screens are removed or slide them so you have glass top and bottom on the storm windows.
Those windows will act as any IMO. When I had the windows like yours replaced the guys put no insulation around the windows, or very minimal. New windows would be a waste of money if thats not done IMO. I had to go around and follow them window by window to insulate to my standards...
They were getting mad at me for doing this...
Old 10-22-14, 01:06 PM
Drapes are far superior to any normal thermopane window for radiant heat loss on a cold night. Whatever you put over the window and even a sheer curtain can be better than the window for night radiation (scientific term is some thing like "black body radiation". This is not the same as the radiant protection by windows for sunlight from the outside during the day.
Windows - A glamorous hole in a wall that costs money and cause some problems, but somehow they are wanted by everyone.
Dick
