Which Flex Seal product?
Old 12-09-21, 08:00 AM
Y
I want to seal a 1/4" drilled hole in the bottom of a metal gutter. In regard to Flex Seal, do you recommend their tape, paste, Quick Shot, or spray? And should I place a piece of plastic or cellphone first before applying the FlexSeal? Or will the FlexSeal material expand enough by itself to cover the hole?
I know there are products made specifically for gutters, but I'd like to use Flex Seal.
Much thanks.
Old 12-09-21, 08:52 AM
P
Received 1,853 Upvotes on 1,659 Posts
Since you've gotta use FlexSeal I would use a piece of their tape. Make sure you thoroughly clean and dry the gutter before attaching the tape.
Old 12-09-21, 11:01 AM
Marq1's Avatar
Received 1,145 Upvotes on 1,038 Posts
Don't use that crap, it's junk,
Just get a tube of gutter sealer from your local building supply, then you wont have to replace in a few months!
Notice that the label says permanent, they can for a reason!
