blower/motor belt alignment
Old 08-26-08, 10:20 PM
A
my tradewinds motor seized up ,with starter windings blown.i believe its due to pulley missalignment.when i installed the new motor i noticed it is off center or rather it isnt in alignment with the blower pulley.all i can imagine doing is adding washers to one of the two mounting bolts on the motor. any suggestions from a pro?
Old 09-11-08, 03:48 PM
D
Hi, I am not a pro but i can help you. take a straight edge and put it on the side of the pulleys and check the pulley that needs to be moved. i have used a yard stick a metal one .
