Bonaire Durango cooler
We just installed the Bonaire cooler and about 1/3rd of the pads are not getting wet and it is blowing warm air. There is plenty of water being fed to it as the discharge hose is draining steadily.
Welcome to the forums.
My first thought is a level issue.
There should be a water restriction washer in the water supply line down near the discharge tee that you could try temporarily removing.
when facing the durango it is on the left side follow the water supply from pump where you have the bleed line coming out of this tube is where you will find the resriction washer
