Pump to element hose has extra drain hose?
Old 05-09-18, 12:52 PM
Received 1 Vote on 1 Post
Smile Pump to element hose has extra drain hose?
I have a question for you guys. The hose that goes from the pump to the top of the element has a fitting in the middle with a1/8 inch hose connector that goes out of the unit and ends up at a vent location. I pulled the hose out of the drain pipe turn on the pump and a considerable amount of water comes in that tube and goes into the drain. I have no idea what itís for, but it appears that hoses capacity is greater that the supply capacity, emptying the water tank too soon.
So, I removed the hose and plugged up the hole and the supply can keep up with the consumption. My question is, what heck is that for? It doesnít look like something temporary or used to drain the supply at the end of the season. Thanks in advance.
Old 05-09-18, 01:08 PM
airman.1994's Avatar
Received 8 Votes on 8 Posts
Lost! Can you take a pic and post it here so we can see exactly what you see?
Old 05-09-18, 03:43 PM
Airman, sorry. Itís at my rental home. But if you know about these coolers, it has a tray at the bottom which holds the source water which is regulated with a float valve and a pump sits in that water tray. The output hose from the pump moves the water to the top of the unitís element, which is a 6Ē thick cardboard looking thing where the water and air mix. That output hose that feedstock top, about one half way up has a fitting in it that allowed an 1/8ĒID plastic tube to fit. That small tube was routed out of the unit and ended at an air vent for one of the roof vents and when the pump was on, it diverted water from the unitís element into that ďdrain.Ē
I hope you can visualize it with that info.
Old 05-09-18, 03:59 PM
Received 1,528 Votes on 1,411 Posts
Your tank should be auto-fill and it sounds like that line is allowing water to drain to allow fresh water to come in. A recycle water to waste line to keep the water from stagnating.
Old 05-11-18, 07:59 AM
pJmax, my problem is, the supply line cannot keep the tank full enough to avoid pump cavitation while that pump to element relief is connected. Once I removed it, all was well. I am worried by removing it, I am changing the design.
I get the idea it is keeping the water fresher than it outerwise would be. Maybe I need to restrict the loss to find a balance?
Old 05-11-18, 08:04 AM
Possibly the pump isn't pumping as much as it was before.
Restricting the bypass line as needed should be ok.
If the water doesn't stay clean you may need to replace the pump.
Old 09-14-19, 03:28 PM
B
The small hose is called a bleed off. The purpose is to remove a small amount of water from the system, in hopes that the mineral level from the evaporating water in the base pan water will be lowered by fresh water coming into the system. If the bleed off is emptying the base pan, you have one of two issues (or a combination of issues). First would be that the bleed needs to be restricted. You can restrict the bleed with an adjustable clamp. Second issue may be that your incoming water supply is too small or somehow restricted. It might even be that the float valve may be plugged up. Hard to tell over the internet.
Although not a fix for your issue, but I might suggest that instead of running the bleed off water into a drain, maybe you could extend the bleed off with some standard garden drip line. Then you could use the bleed to water a tree or some plants? We put our bleed water into a 55 gallon plastic drum, with a hose bib at the bottom. We just turn on the hose bib and water the trees with the water. Takes about 4 days to fill the 55 gallon drum and the trees love it.
