Masterstat Wire burned in control box
Old 05-29-18, 09:23 AM
I have a Masterstat Model 110423-2 from lowes. Third year using this thermostat. I came home and only the pump was running. After some investigation, I found that the link wire was melted and had been getting hot for some time because the insulation was crumbling in my fingers. Anyone know why this would happen? Should I worry about replacing with the same thermostat will have a problem getting hot in the future? It is rated for a 1 HP pump. Anyone else's input would be greatly appreciated.
Old 05-29-18, 02:48 PM
Received 1,531 Votes on 1,414 Posts
Welcome to the forums.
I use those types of terminal strips in low voltage all the time with no problems.
When they are used for high voltage and a bit of a current draw it's extremely important that they are tightened fully. One of those screws came loose and created heat at that point.
Old 05-29-18, 02:49 PM
Thanks, I thought the same thing.
