Need help wiring AO Smith motor
Old 06-04-18, 03:23 PM
T
We have 2 coolers at work that had bad motors. Someone removed them 3 years ago, and threw them away. The replacement motors they bought are AO Smith, model SV2104H.
I have no clue what wire goes where. There are 2 hot (blue) and 1 ground (green).
There is no thermostat, or high low switch inside, just a light switch for the fan, and another for the pump.
Any help would be greatly appreciated.
Name:  AO smith motor (1).jpg
Name:  AO smith motor (2).jpg
Old 06-04-18, 08:30 PM
Received 1,528 Votes on 1,411 Posts
Is there anything on the back of the wiring cover ?
I can't find any wiring info on those motors.
Old 06-05-18, 09:59 AM
T
nothing on the back of the cover.
I think that Century model SV1204hl is the current part number.
I had no luck finding anything on that either
Old 04-11-19, 04:21 AM
Geochurchi's Avatar
Received 91 Votes on 86 Posts
Hi, are you saying the feed to the motor is 2 blue conductors and a ground?
Geo
Old 04-11-19, 12:39 PM
It's been a while since we've heard from this member.
In resizing the pictures I see a HI stamped near the blue terminal. That would mean there should also be a LO stamping. The remaining wire would be COM. You'd connect the two blue 240v wires to COM and to HI or LO.
