On-off-on rocker switch
Old 02-16-19, 10:06 PM
C
How do I determine the amps needed for a rocker switch for my swamp cooler?
Old 02-17-19, 09:44 AM
Received 3,922 Upvotes on 3,518 Posts
Welcome to the forums.
You would add up the amperage of all the parts. That would be the fan and pump.
Typically a heavy duty rocker switch is 10-16A.
Are you trying to match a particular one ?
You could post a picture of it.... How-to-insert-pictures
Old 02-22-19, 04:22 PM
C
On off on rocker switch amp
Yes it's particular and having a hard time finding one. I will read the instructions to posting a picture and get 1 posted.
Old 02-22-19, 06:19 PM
If I'm going to guess you need a switch that has six terminals on it. It will be a three position.... center off type. That would be called a double-pole double-throw center-off rocker. I use those in restaurant equipment. Carling makes a good replacement.
421243 HD switch
Old 02-23-19, 09:26 PM
C
That's close PjMax but I believe mine was 3 terminals. I can't find the old switch for a picture unfortunately.
Old 02-24-19, 10:26 AM
So you need a single-pole double-throw center-off rocker.
A six terminal switch will work in place of a three terminal switch. Usually if the switch controls fan and pump..... it needs to be six terminals. If it's just for a two speed fan.... three terminal is good.
rocker on ebay
Old 02-24-19, 12:30 PM
C
Thanks, I'm going to order the 3 prong one and give it a shot
