Need help, older Sears Rotobelt unit control switch
Old 04-15-19, 07:55 AM
I have an older Sears Rotobelt roof mount, probably late 70s early 80s. The only problem with it is last night, the plastic shaft for the 7 position rotary switch control snapped off. I can't find a replacement anywhere online. My only option may be to take it apart and replace the actual switch. Any ideas?
Thanks
Old 04-15-19, 11:18 PM
Received 1,523 Votes on 1,406 Posts
Welcome to the forums.
The Rotobelt coolers were manufactured by Essick (champion) cooler group. They list a 6 position switch but not 7. You could check with them directly for help.
essickair.com/champion
Old 04-18-19, 01:31 PM
Thanks, the 6 position is not the correct one. They've stopped making parts for the rotobelt models.
Old 04-18-19, 07:55 PM
When you've given up the search...... take the cardboard off the switch and post a pic or two of it.
We'll find a replacement.
Old 04-19-19, 02:48 PM
Thanks, that's my plan for this weekend.
Old 04-20-19, 07:48 AM
Here's the elusive switch
Old 04-20-19, 09:14 AM
Unfortunately the numbers on it mean very little. It could be replaced with a generic switch but the quantity of wires on it as well as what function is controlled at each switch position would be needed.
See if there are markings near the terminals.
Old 04-20-19, 09:16 AM
I've temporary repaired the shaft by welding the broken part back on with a soldering iron, not too optimistic but it's holding for now.
