Bonaire unit water bleed-off
Old 09-15-19, 09:30 AM
I
The manual for Durango window cooler says the bleed-off only operates in the cool mode when the water pump operates. Our unit does not bleed-off when running but does when turned off. Anyone have an idea why this happens and should anything be done to it.
Old 09-15-19, 06:19 PM
Received 1,531 Votes on 1,414 Posts
Welcome to the forums.
The bleeder is in the pump line. It's basically a nozzle that allows water to escape.
If you're getting water out after you shut it off then possibly the fill valve is not shutting off.
Owners manual (pdf)
Old 08-07-20, 11:20 AM
B
I also find the bleed line nozzle clogs constantly with my hard water, which is why I add the purge pump option for about $25 in parts.
