Asbestos siding
Received 0 Votes
Asbestos siding
My house, built back in the 60's, is sided with asbestos siding. Some of the tiles are broken. I can't afford to reside the house so I plan on painting this summer. Does anyone have any idea where these kind of tiles can be found or if there is some sort of replacement available.
Received 1 Vote
1 Post
You can no longer buy asbestos shingle siding, but you can get cement fiber siding that looks exactly like them. They're made of the same stuff as Hardi-Plank.
I don't know any brand names, but I've seen them used, so I know that they are available somewhere.
You might do an Internet search or start calling building supply houses.
Good Luck!
Mike
Good Luck!
Mike
Received 0 Votes
i found some
12' * 24'. They come primed so you have to paint them to match. You local Sherwin Williams can mix you an exact match if you take them an old tile. I ordered 4 boxes and received them 5 days later. They are expensive though 18 @ $110.00. Check it for yourself abccatalog.com
I just had the same dilemma. I own a duplex that has this type of siding on the exterior. I needed a good amount of these because there was a fire, plus I removed windows and wanted the building to look original. There is a company abccatalog.com that makes a replacement. They make a fiber cement siding that is an exact replacement. They offer a variety of styles and had the exact ones I needed,
