2x4 dry rot on bottom
Old 05-30-04, 07:00 PM
pb4sc
Hi,
While replacing my paneling I noticed that one of the 2x4s studs that runs from the top to bottom had the bottom rotted out from dryrot. My question is how to best repair this. Should I cut out the dry rotted section and replace it with replacement 2x4 or should I take out the whole 2x4? Any help is appreciated
pb4sc
Old 05-30-04, 07:52 PM
If this is in the run of the wall and not a corner or king stud for a door, you could sister another to the bad one. Did you find a source of water to cause the damage?
Old 05-31-04, 07:03 AM
pb4sc
rotted 2x4
It is a king stud for the door. The water was coming from the outside, and was pooling on the wood. I am fixing that so it won`t happen again. If it is the king stud....I am guessing I should replace it all?? Thanks for your help
pb4sc
Old 05-31-04, 09:39 AM
Yes, you will need to replace the king stud. Glad you found the root of the problem.
