Mold Before Vinlyl Siding
Old 06-23-04, 07:04 PM
billw
Question Mold Before Vinlyl Siding
Is it necessary to remove mold from wood siding before installing vinyl siding over the wood siding ???
Old 06-24-04, 12:34 PM
C
I would recall that covering up a problem does little to correct it.
You can remove the mildew with a solution of bleach 25% in water with a dash of Tide. Wet the surface, spray on the mixture and let it sit 5 minutes, then hose it off. Protect nearby items by wetting them beforehand and rinsing afterwards.
Hope this helps.
