Plywood vertical siding
Hi, my house was built in 1977 and it has plywood rough sawn vertical siding. I am having trouble finding a few sheets for replacement. The siding is 5/8" thick x 4' x 9' with 1 1/2" wide vertical grooves on 12" centers. The local Manards has some pine plywood siding that matches closely but it only comes in 8'-0" lenghts and I need 9' or 10' long. They can not order it in 9' or 10' long. Does anyone know where this can be found.
Thanks
Thanks
Received 0 Votes
This sounds to be T1-11 siding. If you have found the match in 8 foot lengths, you may be able to order some sheets from the supplier yourself in 9 foot lengths. I did this for some plywood I needed in 10 foot lengths once.
Hope this helps.
Hope this helps.
