Vinyl Siding Shed Doors (Horizontal)??
I have a 10' x 8' storage shed which I am installing Horizontal Vinyl siding on. I also have double doors on front of 10' wide shed - these doors are each 2' wide x 6' high. I also plan to install the same Double Dutch 4" horizontal siding on the doors into Vinyl J channel.
Problem #1:
My problem is that the door bottoms are 2" above where the Wall siding starts. I want the siding to line up horizontally and was planning to cut 2" off the bottom of the Door panels and have them sit in J channel. This means that the bottom panels on each door will not be locked in a starter strip. Do you see any problems or have any suggestions?
Problem #2:
I am also considering installing some Vinyl material on each door and adjacent wall on the side where the hinges are and then installing J channels on each side but set back so the J channels will not jam against each other when the doors are opened. Do you have a better suggestion for this matter?
Thanks
Art
Art Docherty
365 Cedar Ave. RR 1
Meaford, Ontario Canada N4L 1W5
Problem #1:
Problem #2:
Thanks
Art
Art Docherty
365 Cedar Ave. RR 1
You could install hinges with wider plates so that the point where the door swings enables it to clear the other obstructions by extending out past the surface more.
