How to seal gap between siding and concrete
Old 09-21-04, 07:05 AM
The bottom row of siding (hardipank) overlaps part of the concrete footer on my house. There is a gap between the siding the concrete that is probably 1/2" - 5/8" inches wide along the row of siding. It's about 3 or 4 inches off the ground.
What is the best way to seal this to keep water/bugs out of the house? I've thought about insulating foam, but don't know if it can withstand the elements. I'm in Atlanta, where we have hot summer sand cold winters, but not much snow/ice.
Old 09-22-04, 11:14 PM
You can use "Great-stiff" however, there is no solvent.
Old 10-29-04, 06:06 AM
pgtek's Avatar
Received 1 Upvote on 1 Post
hi
try and get some L shape aluminim strips from an aluminium place
and screw it on try to get same color as your siding
cheers
Old 10-29-04, 06:52 PM
H
Don't Seal
You do NOT want to seal this area under the siding.
It is there to provide any condensed water vapor behind the siding to be eliminated to the ground below without obstruction.
Leave it as it is.
