Use of a brick or block wall as siding?
Old 09-22-04, 10:58 AM
notsohandydude
Can anyone tell me what the feasability of using bricks or blocks to basically make a 10'Hx20'L wall as siding along the house? Will this be some sort of insulation?
Old 09-22-04, 12:30 PM
Brick has been used for siding for a long time. It has some insulative value, but not much.
Old 09-22-04, 12:36 PM
notsohandydude
Thanks for the response...
If I have a cement slab as a base for the brick or block wall, would that be fine as a footer for the wall?
Old 09-23-04, 09:03 PM
If the slab for the house has a brick ledge on it, you are in luck. That would be the very best you could hope for.
Old 09-30-04, 12:24 PM
notsohandydude
Thanks. What I have is cement slab right next to the home. I want to just cover the aluminum siding that is there now with a block wall. Can I do that?
ABout 12x12...
Old 09-30-04, 02:41 PM
Hellrazor's Avatar
Block should be set on a footer, ground freeze/thaw in the winter will move the slab around a bit.
Old 10-06-04, 04:10 PM
notsohandydude
Thannks,
Well, I have a cement slab as the footer. Can i just use that with cement for the first row?
