Vinyl Siding Ventilation
Old 10-15-04, 04:17 PM
Damage
Does siding need to have ventilation? Or is there enough airflow between each piece? I am having trouble with mice or something getting in between our siding and our wall. I would like to put some kind of exterior insulation, between the siding and the wall. Is that ok to do? Any help would be great!! Thanks, I live in the northeast.
Old 10-16-04, 07:27 AM
No Ventilation
Vinyl siding does not need any 'ventilation'.
You can use a variety of foam insulating products from fan-fold and rigid foam boards to drop-in style foam backers.
The simpler option amy be to call Terminix, however.
Old 10-16-04, 07:28 AM
Hellrazor's Avatar
One way they can get under your siding is easy to fix. Check your corners at the bottom and see if they are capped.
