? re replacing rotted wood siding under stucco
Old 11-18-04, 06:58 AM
Post ? re replacing rotted wood siding under stucco
Good day all!
My question is:
I have water damaged/rotted plywood siding, which serves as a base for building felt, wire mesh lathe, and stucco for final outer later. I've cut out 2' H by 3' wide sections of the rotted plywood, and replace it with new plywood, which I then add 15 lb building paper, wire lathe, then stucco 3 layers over the lathe.
My ? is: should I use Thompson's water seal on the new plywood? or paint it with a latex, or whatever wood primer? Or something else to prevent or slow future moisture damage?
I'm open for suggestions...my wife just wants me to get it finished, but I want to do it right.
Thanks for any and all your help,
Andy (Majac777)
Old 11-18-04, 08:01 PM
First, you should locate and eliminate the source of the water that caused the damage. Treating the plywood should be unnecessary.
