How thick should exterior plywood sheathing be?
Old 02-07-05, 05:09 AM
jmazur
hi..
currently my project-home (circa 1938) has some cedar shakes, which are directly over some makeshift t&g siding/sheathing. The t&g is approximately 3/4" thick.
i'm planning on residing the house in the spring, and wish to rip off the t&g and re-sheath it with plywood.
my question is, what is recommended thickness?
thanks.
--j
Old 02-07-05, 08:41 AM
T
generally 1/2" exterior plywood is used. i have also seen 5/8" used
Old 02-07-05, 09:12 AM
jmazur
thanks much for your response!
i appreciate it.
Old 02-07-05, 11:17 AM
pgtek's Avatar
Received 1 Upvote on 1 Post
hi
you could used 7/16" osb board to and cheapper than plywood
cheers
pg
