House Wrap substitute under siding
Old 04-16-05, 07:27 AM
I am replacing some siding on a wood frame house with board (actually plywood) and batten siding. The lining between the siding and insulation is black and kind of papery and fibrous - not sure what it is. I need to replace a small area of this material. I have heard about House Wrap and some other product made of Tyvek, but because most houses in south Florida are concrete block, most stores don't carry it. I did find a huge roll at one Lowe's, $150. I only need a few square feet.
Any suggestions for a substitute material? Apparently it has to be breathable but waterproof.
Thanks!
Old 04-16-05, 07:59 AM
Ed Imeduc's Avatar
Wink
Stay in one post on a subject it helps . A MOD will move you if you are in the wrong post.
Like said ask for 15lb felt paper or down here go with 30 lb if thats all they have.
ED
Old 04-30-05, 03:57 PM
The black paper between the old siding and insulation is felt paper. Before Tyvek, felt paper is what was used to wrap a house.
