how do I remove aluminum siding
Old 05-04-05, 11:40 AM
djmikey
Cool how do I remove aluminum siding
I want to know how to remove aluminum siding without destroying it . Is there a way?
Old 05-04-05, 04:11 PM
XSleeper's Avatar
Received 243 Votes on 224 Posts
Start from the top and work down.
Old 05-04-05, 07:16 PM
Received 139 Votes on 124 Posts
Very Carefully !!!
Old 05-13-05, 11:03 AM
Received 1 Vote on 1 Post
removing vinyl siding
Get a vinyl siding removal tool which looks like a bottle opener-it is an elongated handle with a lip on it which slides under the vinyl piece-no need to start at the top-take any specific piece of with it. Try home depot or lumber yard. Call 1st or go online.
Old 05-15-05, 04:25 PM
You have to be real careful if you want to save it. (I can't imagine y u would want to save it.) But any how start at the top and very gingerly pop down that piece as it shouldn't be nailed. Then just work your way down pulling the nails.Remember it is very easy to crimp the panels. Lots of luck
Jarhead
Old 05-16-05, 09:55 AM
siding removal
Use the siding removal tool I described-'unhook' the piece and take the nails out-just work in the damaged area, unless, you want to remove all the siding THEN start at the top and after popping the top piece just pull nails as youwork down.
