How do you install 4' x 8' fiber cement panels?
I have a garage that is presently sided in car siding that is in pretty bad shape (from moisture rot) in some spots. There are not interior walls in the garage--only the exposed studs that are 24" on-center.
The 4' x 8' fiber cement panels are 7/16" thick.
Does anyone know if I can attach the fiber cement panels directly to the studs?
If so, will it cause any problems?
Thanks.
Thanks.
Yes, but building paper must first be installed. See http://www.jameshardie.com/homeowner...stallation.php
