Cedar lap siding question without sheathing
I have a 15-year old wood-frame house bought less than a year ago and only recently noticed that the attics have cedar lap siding attached directly to the framing studs. There is no plywood sheathing behind the lap siding. Is this likely to be up to code?
If not up to code, what would be the simplest way (without removing the siding) to correct the problem? I was thinking of spanning the space between sides with plywood and securing with 2x4s nailed or screwed to the framing studs.
Also if not up to code, do I have legal recourse with the previous owners or builders?
Codes vary from place to place and also change over the years.
I doubt you would have any recourse with the builder or previous owner.
Are you having any problem with the siding? Is the siding below the attic installed that way also? I know some of the older homes had siding installed in that manner.
No, the house wall siding is plywood with vertical boards to make it look like board and batten. This is only on the attic ends of the gable roof. I am in Florida so my main issue with the attics is impact/wind resistance.
What do you think of my retrofitting solution? The problem with removing the cedar siding to correct the problem is two of the attic walls are above the second story, one of these above a sloped roof so access from outside would be a major issue. Any other ideas?
