No soffits
Old 01-06-06, 11:51 AM
No soffits
I've taken on a siding job on an old garage. Question is, there is no soffits on the front and back, in other words the roof does not overhang. HOw should I finish this? Should I use j-channel or perhaps the around the window type siding? As you can can probably tell I'm new to this and dont know all the terms and whats available. Thanks for the help in advance, I also have pictures if it helps.
Old 01-06-06, 05:42 PM
XSleeper's Avatar
Received 284 Votes on 260 Posts
Hi sukevin!
Since you have pictures, why don't you post them to a file sharing website like yahoo, then paste the link here. We'll take a look.
Old 01-09-06, 12:05 PM
OK, here are two pictures
http://us.f13.yahoofs.com/bc/43c2b40...Z.rwDBmHUk7Jpw
Old 01-09-06, 12:22 PM
Links don't work for me.
Old 01-09-06, 12:26 PM
Anything happen
The pictures are kinda large, did they links attempt to take you to a new page or what?
Old 01-09-06, 12:33 PM
Server not found
Firefox can't find the server at bcvrf.yahoo.com.
* Check the address for typing errors such as
ww.example.com instead of
www.example.com
* If you are unable to load any pages, check your computer's network
connection.
* If your computer or network is protected by a firewall or proxy, make sure
that Firefox is permitted to access the Web.
Old 01-09-06, 12:36 PM
THey work for me using 3 isp's
YOu may have to have a yahoo id. OTherwise, I have no idea. Sorry
Old 01-09-06, 01:18 PM
Old 01-09-06, 01:56 PM
XSleeper's Avatar
I'd recommend you tear off the old siding, but leave the existing fascia trim boards on. Remove any trim boards that aren't necessary, like your corner trim boards and any other boards they nailed up for no reason. Install j-channels around windows and doors, and use vinyl corner posts on the corners. You would want to rent a metal break and buy some trim coil, then cover any 1x4 trim that you want to keep. There's a good way to bend the fascia cover which can eliminate the need for j-channel in those areas, I'll post a picture of it later.
Old 01-09-06, 05:54 PM
XSleeper's Avatar
Here's the link to the illustration I promised:
http://pg.photos.yahoo.com/ph/thexsl...nm=3f2dre2.jpg
Old 01-09-06, 05:56 PM
thanks sleeper
thanks alot
