use bleach or not?
Old 05-27-06, 08:08 AM
use bleach or not?
I am pressure-washing my house to remove mildew in prep. for painting...do I need to use any bleach in the mix?
Old 05-27-06, 10:11 AM
My pressure washer booklet is full of warnings to not run bleach through it.
Old 05-27-06, 05:06 PM
Received 118 Votes on 105 Posts
I never run any chemicals through my pressure washer. I prefer to use a pump up garden sprayer to apply any cleaner. Bleach [dilute minimum 50%] is necessarry if there is any mildew to be killed/cleaned.
Old 05-27-06, 08:19 PM
chandler's Avatar
Received 2 Votes on 2 Posts
Have either of you used JoMax siding cleaner? Does it help with mildew. I know it is formulated specifically for vinyl siding, but thought it may have "secret" ingredients beneficial for removal of the green.
Old 05-28-06, 04:07 AM
I haven't used jomax cleaner, I seldom use any of the 'specialty' cleaners. Bleach is cheap and works well for mildew. I think most of the deck and siding cleaners have a bleach substitue which basically does the same thing. If I understand correctly the package cleaners are a little more user friendly because they won't damage the wood if applied too strong or not rinsed soon enough.
As a painter the majority of pressure washing I have done has been incidental to painting and have only washed a few vinyl sided houses.
Old 05-31-06, 08:20 AM
thiggy's Avatar
I have used JoMax in preparation for painting and it works great! I then used Zinsser's paint for the top coat, following the manufacturer's recommendations.
