Vinyl siding
Old 05-05-07, 01:17 PM
T
Red face Vinyl siding
I had some damage done on two pieces of my vinyl siding. the question is how do you remove a piece which is between two windows and installing another piece. I have extra sheets to do this.
Thank You
tommy1
Old 05-05-07, 02:47 PM
chandler's Avatar
Received 9 Votes on 8 Posts
Welcome to the forums. It is relatively easy. On the piece above the uppermost damaged piece, you will need to hook a tool (and they make one you can get at a siding supplier) under the sheet and pull down and out on the panel. It will release and will expose the nails on the piece directly below it. Don't remove the nails on any of the pieces, just pull down and out on the damaged panel(s) as the tabs will flex enough. Cut the new pieces and replace on the existing nail heads and flex the piece over the rail of the one below it, using your newly found tool. Any questions, just post back. Good luck with it.
