Caulking of nailholes
Old 04-28-08, 11:47 AM
D
New wood clapboard siding applied, should we caulk nailholes with painter's caulk and wipe smooth, or should some other compound be used that requires sanding?
Old 04-28-08, 04:59 PM
Received 786 Upvotes on 689 Posts
Welcome to the forums!
Caulking is fine although it may shrink a little and a keen eye will be able to pick out the filled nail holes after it's painted.
Personally I wouldn't use an exterior spackling or any other filler that might require sanding. Painter's putty or window glazing will do a good job of filling the holes although it may require priming to keep it from bleeding thru certain paints.
