Replacing rotten wood
Received 0 Votes
I am about to have my house painted and there is a significant amount of rotten wood that needs replacing. The rotten wood, as well as the wood on the entire house is pressure treated or as the painters call it, "green wood." I've had to paint my house about every 5-6 years and each time there is a significant amount of rotten wood, and frankly, I'm getting tired of the extra cost involved in replacing the rotten wood prior to painting.
Furthermore, I've not been happy with how the pressure treated wood holds paint. It consistently peels in places. I know some will blame this on the paint used and others will blame it on the painter, but we've used different paints and different painters each time, with the results remaining pretty much the same. In fact, the house next door has cedar trim, and one year, we used the same painter and paint as the neighbor. Their paint job held up much better than ours, and I can only surmise that the wood was a major factor.
My question is: Is it OK to replace only the rotten pressure treated wood with cedar or some other material? I've talked to a couple of painters about using cedar, and one steered me away from cedar, saying that pressure treated wood held paint much better than cedar. The other painter just looked at me kinda funny and said that if I wanted cedar, I should replace all the wood with cedar, otherwise, I should just replace the rotten wood with pressure treated.
Other than the texture of the wood (all of which will be covered by paint and some of which will be covered by gutters), I don't see a problem with mixing the woods, but I'm certainly not an expert. What say the experts?
As an alternative to cedar, I thought about Hardi Plank. In general, I'm looking for something that will not rot so quickly and will hold paint better than what's been used previously on my house. Because cost is a factor, I don't want to replace all the wood on my house. Any advice anyone can give me on this issue would be greatly appreciated.
Fresh PT wood never paints well!! It needs to dry out and weather some before it will hold paint. Often the better wet PT is painted, the quicker the paint will fail.
I'm not sure I understand why/where PT is used on your exterior. Generally PT has limitted uses on an exterior [other than a deck] Am I to understand that the PT wood is deteriating? You need to determine the cause of the rotten wood and correct it first!
Generally cedar will paint well. The main issue with cedar is tannin bleed which a good oil primer will normally take care of....... but if the PT rots, I woouldn't expect cedar to fair any better. You need to find and address the cause of the rotting wood.
I am assuming you are talking about trim wood. If so, check into Miratek. It is quite stable, has a grain similar to cedar, comes already primed. I don't feel comfortable with them using pressure treated lumber as trim boards. It takes a while for PT to accept paint, and if it is painted too early, it will, as you found out, peel the paint right off. Miratek comes in a 5/4 size and a 4/4 size, which, in reality means 3/4" and 1" thick in 4 & 6" widths in 16' lengths.
I agree with others that you need to figure out the source of the moisture problems first. Sometimes it involves getting suited up during a rain storm and actually watching how water flows on your building.
It is my experience that you need to let PT lumber "age" for at least 6 months before trying to paint. Then you need to prime it with an old based primer. Preferably one that will accept a latex overcoat. However, I also agree that using PT for trim would not be my first choice.
If you use wood, try painting the boards before you install them. That way all 4 sides will be sealed. Once installed, you can caulk, fill nail holes, and apply a finish coat as necessary. Also, don't forget to paint the end cuts and leave a space between the bottom of the board and the ground or concrete to prevent wicking up moisture. This wicking is the cause of many trim problems with rot around door and window brick moldingl and garage door trim.
There are multiple companies that produce expanded PVC trim boards. As they are not made out of wood, these will never rot and except paint well.
Received 0 Votes
Yes, the rotten wood on my home is trim. I understand that trim near the ground is subject to moisture wicking from the ground surface, but the rotten wood that is really annoying me is fascia (sp?) board, generally found behind my gutters. I also have a couple of spots (on the roof line) where animals (likely squirrels) are scratching and chewing on the trim boards, but that is not a moisture issue.
Being that more than one of the respondents have mentioned that PT wood needs to dry a significant amount of time before painting, I think that is most likely the source of the problem. I know one of the painters I spoke to would be buying his PT wood at Home Depot, because he said that HD doesn't sell cedar for my trim, so he'd have to make a special trip to a lumber yard. And, I know that the PT wood at HD and/or Lowes is pretty wet in the store. I'm sure they (Painters) just go buy it in the morning, slap it on in the afternoon, and then paint it the next day. One painter made a point to say that they prime the PT wood, but I would assume that if wet, even the primer would peel. Is that a correct assumption?
Also, I don't know if this has any meaning, but when the paint peels, it peels off in big pieces, as if it didn't adhere at all over a large section.
Chandler, is Miratek from this website? How is Miratek different from Hardi Plank? And, now that I'm learning a little bit more, is Hardi Plank not an appropriate material for trim application?
Thanks again for all of your advice.
Miratek is one product, there are also Azek, Plasticlad, Koma Trim boards that are an expanded PVC. I'm sure you have seen the "Never Rot" products at the box stores. They are a plastic instead of a wood based product. Hardie Boards and trim are cement based products so there in lies the difference. Plastic based products expand and contract more than cement based ones. Either one will not rot.
As far as you squirrel damage, that has nothing to do with your original post, except for the fact that the animals chewing on the wood have exposed the wood to the elements which in turn could cause rot. If you used PT lumber to seal these areas, and then had the paint issues that could be whats going on.
The squirrels are trying to get into the attic area, and probably have already succeeded. You need to clear the animals from the area if you want to have a successful repair. IMO they will chew through whatever you have there be it plastic, cement or wood based. I have a client who had squirrel problems, he had an exterminator come out and set traps to catch the attic residents. They then sealed the holes with tape and waited to see if the tape was broken over the next few days. If broken, then they knew more squirrels needed to be trapped. They continued until the tape remained intact. Then he proceeded with the repairs.
It sounds like your gutters aren't installed properly. Lack of a drip edge on the fascia can also contribute to moisture geting behind the gutter. If you can solve that problem, you likely won't have anymore issues........ except when critters remove the paint exposing raw wood
Received 0 Votes
I think a trip into the attic is in order. Squirrels love to chew on things, helps keep their teeth in good working order. I would also highly recommend that you inspect all the wiring up there as squirrels also love to chew on the insulation around the wires. This creates a major fire hazard. Which may change your mind about the "humane" concerns about your uninvited house guests.
I have seen live wires stripped clean of all insulation. One occasion, I saw a 2ft run of completely bare copper (3 wires set parallel to each other). I found them in the dark as I was working my way over to install wire mesh over a gable vent (to stop the squirrel access). I stepped over the HVAC ductwork and saw a flash around my feet. Shined the light down and the bare wires were there. There was also a dead squirrel carcuss next to it.
I double checked a couple of the company websites regarding expanded PVC trim and none said anything about not being able to be used in Texas
The key is accounting for the boards expansion. If you install them on a hot day, then they are already expanded. If you install them on a cold day then each company recommends how much expansion to account for.
Mike, was in Denver a few months ago to visit Daughter (really grandkids), but went in a HD and they had 2 x 8 x 16 clear redwood. I drooled alot. Transportation costs would make it horribly expensive here in the South.
