Wood J channel?
Old 05-29-08, 01:15 PM
G
Wood J channel?
I found a few sources which show people using wood to cap the ends of vinyl siding. But when I talked to my local lumber yard they said dont do it because it will rot long before the vinyl. lol
I have a north facing front door and dont want j channel around it. I want to router a groove into the existing wood brickmold to except the ends of the vinyl siding.
Is this a bad idea? Can a router make this cut? The door has a 3' soffit over it and rarely sees rain. And the brickmold has been rot free for 20 years.
Thanks
Old 05-29-08, 01:39 PM
W
Received 45 Votes on 42 Posts
Brick Mould
After you router the brick mould and install the siding, how will you get enough paint into the routed groove to prevent rot?
Old 05-29-08, 07:23 PM
C
As a suggestion, painting the groove first might be in order.
Old 05-30-08, 04:30 AM
W
Groove
Chfite is correct for the initial painting. What about 10 years from now when it needs to be painted again?
The router groove needs to be 7/8 in. wide. The router will not cut all the way to the bottom if the brick mould is resting on the threshold.
Old 05-31-08, 05:36 AM
czizzi's Avatar
Received 15 Votes on 13 Posts
I would do it as a 2 piece installation made out of PVC Brickmold trim. Rip the PVC Brickmolding down to a narrower depth by the amount needed to inset the vinyl siding. Appropriately flash or seal the door jamb on all sides. Place a nominal 1" x 1" as an offset and nailing surface on the door jamb. Install the vinyl siding up to this and cap it with the new narrower profile PVC brickmolding.
Old 05-31-08, 10:03 AM
G
Thanks everyone.
I agree czizzi.. Thats the best way. But its a existing door and I will have to use the J channel.
In my opinion, the J channel and short 12' material lengths make vinyl siding look cheap and generic.
I cant believe no one makes vinyl brickmold and trim with a pocket built in for vinyl siding.
Old 05-31-08, 11:16 AM
XSleeper's Avatar
Received 1,446 Votes on 1,302 Posts
That sort of thing (vinyl brickmold and trim with a pocket built in for vinyl siding) can be custom made with a metal break and trim coil. Lots of guys do it that way, since it looks a little cleaner.
Old 05-31-08, 11:25 AM
Gunguy45's Avatar
Super Moderator
Received 4 Votes on 4 Posts
Well, It's not wood...but take a look here. Ahh, yer not even looking for wood. Ok, here ya go. Not cheap tho, and I think they have minimum quantities if you order at yer local box or builders supply.
http://www.royalbuildingproducts.com....html#pvc_trim
Old 06-01-08, 08:37 AM
G
Nice! Now I feel stupid cuz thats the brand siding I used. I had to travel to get it.. Im the homeowner and installer.
Maybe the next house...
