Replacing metal siding...
Received 0 Votes
Hello,
I have an old moble home in Michigan. A storm blew a pine tree onto the back side. Most of the damage is to the metal siding. Where do I go to try to match the existing siding?
I don't know if you can find replacement panels or not. I doubt you can get an exact replacement. You might try contacting the MH manufacture or inquiring at a MH supply house.
Usually when an older MH gets damaged like that, new siding is installed - not aluminum but plywood/vinyl siding or T-111, hardi board, etc. It will require proper flashing!
