Venting cedar siding
Received 0 Votes
I have a house that has bubbled alot of the paint on the cedar siding. Benjamin Moore has been out and says that the cedar siding has to be vented. Any ideas? I have heard of sticking shim wedges under the siding at various places. Is there anything else that can be done?
Welcome to the forums!
The best way to fix the moisture problem is to install a vapor barrier on the inside........ but that requires removal of the interior walls
On older homes without a proper vapor barrier, it is recomended to use all latex primer/paints. Moisture can travel thru latex better than it can thru oil base. Cedar presents a problem because of tannin bleed which needs to be sealed with good solid coat of oil base primer.
I have also heard of shimming the lap siding but don't recall ever painting a house where this had been done. Are there certain areas of the house that the paint bubbles more than others?
Received 0 Votes
No. The siding is mainly in the rear of the house, except on the second floor, which has some sidingon the side. Most of the house is stone ( the front and 90% of the sides ). The house is between 10 and 15 years old. The peeling/bubbling appears randomly on the siding. Where it is peeling/bubbling it is not just a little spot. It's at least 4 - 6 inches in each spot.
Thanks for helping,
Steve
Thanks for helping,
Steve
Wait
Before going further, give those paint guys a credibility check. I had a standard latex paint over my cedar siding for 15 to 20 years with no problem. Then I scraped and sanded it, primed any bared wood, and repainted it with a fancy 100% Acrylic Latex paint. Same siding, but the paint blistered like crazy. When I cut away the blisters it appeared that the new paint just would not stick to the old paint where it was sanded thin. Not quite bare wood, not quite a thick undercoat. But the blisters ballooned on a warm day, then sagged when cool. Ugly! So I'm cutting away blisters, sanding the edges, priming heavily and repainting the spots. Then I'll give it all a new topcoat. My fault? The paint's fault? Dunno, but it's not the fault of moisture in the siding or the previous coats would have bubbled long ago.
