outside corner vinyl siding problem
Received 0 Votes
problem: outside corner on back of a bungalow/ranch house is not trimmed properly
The back of the house has the foundation only going about 2 feet above grade, and then a pony wall finishes the exterior basement wall.
On the outside corner
- the side of the house is poured concrete to the 1st floor
- the back of the house is the above pony wall
- the vinyl siding contractor did not trim this corner properly, so the back and side of the sheathing (tongue and groove boards) are exposed to the elements.
- Contacted the contractor and got him to look at this area, and said that was how it is supposed to be.
- It appears they took a piece of narrow J-trim and cut the bottom of the J off. looks great from the back of the house, but from the side you can see the sheathing because the trim doesn't the end nor back of the wood.
Thanks in advance for any assisstance
Received 0 Votes
photos of siding problem
It looks like they could have covered that with some aluminum trim coil that is the same color as your siding. Maybe they didn't have any, and that's why they tried to use the piece of j-channel. Reminds me of some expression about a purse and a pigs ear, but I don't know exactly how that expression goes.
Looks like that area was exposed in the past with the paint on it. If you can get them to come back, they might be able to cover it with a small piece of trim coil. Otherwise, (hard to tell what the size of that area is) I would think that a 5/8" wide nozzle on a caulking gun would cover up that area, provided the caulk matched the siding color.
Received 0 Votes
Thanks for the help.
I did contact the manufacturer as well, and they suggested the same thing as yourself.
The house had "color lock" siding, glorified cardboard, for the first 33 years of its life.
The outside corner was covered with some kind of wood trim where the concrete and the ponywall met up
