Caulking Vinyl Siding Where It Meets Windows
Received 0 Votes
We just moved to Tennessee and bought a house that has Vinyl Siding. (12ft lengths in strips). (House built in 99). Anyway I have noticed that Mud Dobbers (not a lot) have been making their way behind the siding where Vinyl meets the windows. Can I used Caulking to prevent them from getting in there? If so what kind? Also will it hurt to Caulk ALL of window frames that have gaps in them?
Caulking the outside of the j-channel where it meets the window is one thing... but caulking the siding INSIDE the j-channel is another- actually it would be a big mistake. Not only would you use several CASES of caulk, but it would make a holy mess and could potentially ruin the looks and value of the siding. Vinyl siding needs to have room for expansion and contraction which is why the siding fits loosely inside the j-channel, whereas caulking the ends of the siding shut would pin the end of the siding to the j-channel so that it couldn't move.
I would strongly advise you against that plan.
Received 0 Votes
Picture is worth a 1000 words. As you can see I have caulked the top 2. The caulking I put in there is like if you were to put Cotton in your ear. It is right there on the surface (not tucked back in)
Thanks Lee
Those are the only 2 I have done...
Received 0 Votes
Received 0 Votes
The other thing is that caulk naturally attracts a lot of dirt. In a year or so you'll find that you have some real nasty areas there. I'd also recommend just avoiding it and dealing with the wasps.
Your comment about cotton balls makes me think that maybe they would look just as good... er, bad? as the caulking... could always be removed, allow the siding to move... and satisfy your wife.
The mud daubers are just storing their spider carcasses for winter in the tubes. They can be washed off with a good force of water, but wait until spring when they will be empty. No matter how much caulking you do (and I wouldn't) you won't stop them. Welcome to the South!
Received 0 Votes
I may try the cotton balls and see what happens...
