what is a MITER CUT "
Received 0 Votes
I know what a miter saw is but what exactly is a miter cut? is it just a cut that is an angle,like a 45 degree angle? what the heck is it? when is it most common to use a miter saw?
thank you
thank you
Typically you cannot adjust the saw blade angle with a normal table saw. A miter saws table and saw blade can be adjusted to the right angles.
They also sell miter boxes, which is basically a plastic box with grooves and you use a normal hand saw to cut your material.
What are you trying to cut?
Received 0 Votes
first off,thanks for the info,nice of you to take the time.
anyway,just confused with all these new tools.
for example,what is a planer used for?
what is a chop saw used for?
is there a special saw one would use to trim the thickness of moulding for example; cut the corner on an angle but at the same time trimming the thickness on the corner only?
Here is a good Wiki link.
http://en.wikipedia.org/wiki/Power_tool
You'll prob find more complete info than what most people have the time to post here.
