I have 8" aluminum siding on the house & I'd like to build an attached yard shed. I believe the aluminum siding is installed right over the original siding from 1962.
What is the best way to handle the existing siding when attaching the studs for the shed to the house? Do I need to cut it, remove it, leave it? If I leave it is there something to fill the gap between the stud & siding?Read More
I'm intalling exterior plywood over 30# building felt. The plywood is both the sheathing and siding, per architect's specs for framing in my carport. Should the builders paper be installed horizontally starting at the bottom of a wall, with a particular amount of overlap?Read More
