Holding force
Old 01-26-10, 03:39 AM
Received 1 Upvote on 1 Post
Holding force
I'm probably not using the right words here, but how would I determine the amount of weight that can be supported by fastener attached into the narrow side of a 2x4 framing member with nails or lag screws of certain lengths?
Old 01-26-10, 05:48 AM
W
Received 61 Upvotes on 53 Posts
Holding Force
Are you talking about something like hooks in a porch ceiling to support a heavy load such as a porch swing?
Old 01-26-10, 07:05 PM
Exactly, that's one application. I was also wondering about hoisting things from exposed ceiling rafters.
Old 01-27-10, 05:28 AM
W
Holding Power
I would not advise any type of fastener inserted into the 2x4. The needed hole would weaken the wood. Go for something which encircles the 2x4 without penetrating it.
Old 01-29-10, 05:24 AM
I see your point about nailing into the narrow edge of a framing member, but how to explain that Framing connectors (like plate ties and hurricane straps) are designed to be nailed into both sides of the narrow edge of a stud to hold the studs to bottom and top plates. And they hold roofs on . . .
Old 01-30-10, 04:31 AM
OK, Wirepuller was talking about ceiling rafters and the last one was about nailing to a vertical stud. For the rafter, it makes sense that you'd want to go around the member and not just nail to the bottom edge.
For a stud, a lot of supporting-type hardware (hangers, cabinets, even fall anchors and scaffold systems) is nailed or screwed to the edge of vertical studs. Just wondering how I could determine load limits for that kind of arrangement. Are there tables somewhere?
Old 01-30-10, 11:58 AM
W
Fasteners
Tell us what you are trying to fasten and some one will tell you what fastener to use.
Old 01-31-10, 09:22 AM
Well I've been trying to avoid THE SAFETY LECTURE but the vertical stud question is about fall protection. I need to work on my second floor gable ends, don't have $4,000 at the moment for a contractor to do it, and am considering 2 ladders with ladder jacks and an aluminum plank and I'd like a backup point to attach to using a harness. I'm looking for commercial options, am not finding anything except things designed for open framing, and was wondering about taking a roof ridge anchor (the kind that bends over the ridge under the ridge vent) and nailing it to a vertcial stud, and attaching to the bottom D-ring. It would have to fasten through one layer of 5/8" plywood. Another idea is a SS U-bolt through the plywood, and fastened around the back of a stud.
The rafter question was about hoisting stuff in general from ceilng rafters. The most pressing need is to lift a 600-lb table saw off its base.
