Foundation Siding
Old 05-25-11, 12:49 PM
Foundation Siding
Hi, I just had my house built last fall and the contractor only sided down to the top of the foundation and since it is a walk out basement with stepped down side foundation walls there is alot of concrete showing above the grade. I would like to extend the siding down to the ground. The questions I have is how to attach the siding to the concrete? Everything I have found says to use furing strips but won't that make the foundation siding stick out noticably farther than the rest? Also since you install siding from the ground up, whats a good technique to make sure it snaps together well from the new to the existing? Thanks!!
Old 05-25-11, 12:58 PM
Received 62 Votes on 58 Posts
Welcome to the forums
What kind of siding?
Old 05-25-11, 01:13 PM
Thanks! Its vinyl siding, sorry I forgot to mention that.
Old 05-25-11, 03:30 PM
Received 168 Votes on 149 Posts
I'm not overly fond of vinyl close to the ground..... if a weedeater gets near it
Have you considered applying stucco to the bare block?
