heavy slate tile as an exterior wainscot
Old 07-02-11, 06:21 PM
Recently I have seen two homes with slate tiles for exterior wainscot.
Frankly, it looked really good.
why is this not used more often? real and fake stone products are common on exteriors. slate is relatively common on roofs- why not exterior walls?
(how do i insert an image directly to the post?)
Old 07-03-11, 03:07 PM
Received 62 Votes on 58 Posts
I like the look of brick on an exterior but not stone
Go figure
Old 07-03-11, 05:12 PM
i guess i need an exterior rated tile or slate. impervious or vitreous?
Last edited by stickshift; 07-05-11 at 07:07 AM. Reason: removed quoting of entire post
Old 07-03-11, 08:34 PM
chandler's Avatar
Received 3 Votes on 3 Posts
Stone is stone. It is not impervious. Water will get behind it. It is the protection you put up to protect things that make it all work right. I'll have to agree with Mitch...I like either brick or dry stacked stone for the exterior. The pix in your example looks too much like Joseph's coat...too many colors and no pattern.
Old 07-05-11, 07:09 AM
I don't like to use natural stone products because they are not impervious to water, so there's extra maintenance involved
In your case, it might be possible to put up porcelain tiles which look like slate and avoid that issue, though I do not know what kind of installation parameters would be involved, I've only ever installed it on floors.
