Cleaning vinyl siding/
Old 09-01-11, 07:31 PM
Cool Cleaning vinyl siding/
Products to clean off spores and spider crap on vinyl siding.
Hopefully easy on plants and the user. I have used simply green. It cleans the dirt but not the spores or spider crap. HELP!:::
Old 09-02-11, 05:02 AM
Received 142 Votes on 127 Posts
Welcome to the forums!
It will probably take a little scrubbing to get those spots clean. A brush that can be screwed onto a roller handle should help make the scrubbing a little easier to do.
Old 09-02-11, 11:15 AM
Received 54 Votes on 51 Posts
I can't think of any product that would clean that stuff off the siding without scrubbing and without damaging the siding in the process.
You're going to need a little elbow grease on this.
Old 09-16-11, 08:25 AM
Nanrepair's Avatar
Have you tried simple green on a brush then power wash the tough spots after soaking. We have an upper deck that hangs over the walkout basement and the spiders love it. There were also a ton of cocoon things too that I couldn't get off unless I blasted them with the power washer. If you don't own one of them rental is fairly inexpensive and should make short work out of it.
Old 09-16-11, 09:04 AM
Have to be careful with vinyl siding and a pressure washer not to get the water under the siding
Old 09-16-11, 01:51 PM
Ya, when washing vinyl siding it's best to aim the wand downward. When you shoot the water upward there is a good chance the water will get behind the siding In other words - that means you need to get on the ladder or have an extension for the wand.
