Square footage to board feet conversion
Old 12-15-11, 07:23 PM
R
Question Square footage to board feet conversion
How do I convert from Square footage to board feet? Then calculate it on a excel spreadsheet, Thank you,John
Old 12-16-11, 03:52 AM
chandler's Avatar
Received 9 Votes on 8 Posts
The math part: Depends on what size board you are using. An 8" nominal board is figured at .666. So a 1x8x12 would equal 12 x .666= 8 board feet (closer to 7.5, considering an 8" board is 7 1/2" wide). A 10" nominal board would be 12 x .833 = 10 board feet. Take the width, divide it by 12 and multiply it by the board's length. Now as far as square feet, I am assuming you are figuring an entire wall's square footage??
See Board Foot Calculator for a board foot calculator.
Converting to square footage How to Convert Square Foot to Board Foot | eHow.com
Old 12-16-11, 02:58 PM
W
Received 45 Votes on 42 Posts
Board Feet
1 board foot is 1 square foot one inch thick.
length(feet) x width(feet) x nominal thickness(inches)= board feet
In Exel:
Length in column A
Width in column B
Thickness in column C
Board Feet in column D
Formula in column D: A*B*C
Hope this helps.
