Go Back  DoItYourself.com Community Forums > Exterior Improvement Center > Exterior Paneling and All Exterior Sidings
Reload this Page >
What type of nails we should use for wall frame on storage shed in our backyard
Old 05-11-12, 09:50 PM
V
Question What type of nails we should use to complete storage shed in our backyard
We finished floor and sub floor and now
Please tell us nails we should use on wall frame as well as on roll roofing.
I have been told 16d common for wall framing ...correct me if am wrong...
Two of the four walls will have dimensional lumber 2x4 at 16" center
and other two will have pressure treated 2x6 again 16" center ..so advice accordingly.
Old 05-12-12, 04:30 AM
Received 598 Votes on 531 Posts
12D should be good enough. Any nails that go into or thru PT wood need to be galvanized - rated for PT contact. Regular nails will corrode over time.
Old 05-12-12, 05:19 AM
chandler's Avatar
Received 9 Votes on 8 Posts
Wall construction should not be of PT lumber. Switch to SPF or other non PT lumber. The PT will shrink in time and cause problems. Use 1 1/2" galvanized roofing nails for your shingles.
Old 05-12-12, 10:31 AM
V
Question can we use roll roofing for low slope flat roof
can we use roll roofing for low slope flat roof?
if pt would shrink over time..why are they used on floor?
Old 05-12-12, 10:46 AM
Gunguy45's Avatar
Super Moderator
Received 4 Votes on 4 Posts
Roll roofing is not the best choice for a low slope roof. Some sort of torch down would be better.
Old 05-12-12, 10:56 AM
chandler's Avatar
Either torch down, or modify the roof structure for proper slope and drainage. What is your snow load and what size lumber and span are your roof rafters? PT is used on floors and the shrinking isn't important, there. It is used on the floor to prevent water from damaging the wood.
Old 05-12-12, 10:59 AM
V
we are in Lakewood WA so we have snow sometimes...we are going to use 2x4 on 16" center for rafters..
Old 05-12-12, 11:18 AM
V
so for pt lumber what would you choose between 16d hot dipped galvanized spiral nails vs 16d vinyl coated sinker? also what would you choose among above two for non treated lumber?
