cleaning vinly siding
New Member
Received 0 Votes
installed new siding approx 10 years ago....I'm repainting the shutters..and rrealized the siding needs cleaned badly...i have a power washer.....what is the best method to clean the siding...what cleaning agent is best for vinly siding...also can i clean up the alum gutters the same way/...thanks
Just make sure you always have a downward angle on the water relative to the siding, you don't want to push water up underneath it.
I'd use dish soap or something similar for this (unless you know what caused the problem and it indicates a particular solvent would be best).
If soap and water doesn't get it, try JoMax, sold at box stores and others. It is made specifically for vinyl siding. Apply it with a pump up sprayer, then medium force from the PW in a downward angle as mentioned.
