Vinyl Siding - outside corner post angle or not????
Received 0 Votes
ok, I have pretty much replicated the soffit and fascia trim for my shed out of PCV trim as it looks in the attached picture (not my shed, but darn close now).
Now, for the corner posts however, I am just going to use plane old vinyl siding corner posts because I am siding the shed.
I'm pretty sure I can replicate the corner post angles as shown in this pic with the side under the soffit being somewhat higher than the end of the angled cut of the rake edge fascia.
Is this what I should do, or are there other recommended ideas to consider? I imagine the siding portion of this project will go fairly quick, so I thought I'd better ask now.
I don't intend to use any PVC trim boards for the outside corners, just vinyl siding outside corner posts.
Not sure why your asking or why.
There is no other way to do an outside corner with vinyl siding, PVC trim would and should never be used.
Without a real picture of your shed it's hard to suggest what you may run into.
The one in the picture you posted has no over hang on the rake so an outside corner would stick out past the rake board and allow water to run down inside of it and look like poop.
Yes, that is what you should do. If you don't yet have a sliding t-bevel, get one. It's invaluable for that sort of thing.
Another no tools need way to figure out the angle is to just side the outside corner up tight to the lower side and measure the distance from the high side to the rake.
That's the distance to make your mark and remove on the low side.
Received 0 Votes
Received 0 Votes
ok, I just held together a couple of pieces for these pictures, but I'm hoping for some info/opinions...
Here's kind of what I was referring to...aside from me not being the best at cutting this angle, which would it be better to do, leave the top up against the fascia on the gable, or slide some J channel in above to try to make it a bit neater?
would sliding the J channel in cause any issues with water or anything like that?
If the angle was cut better the top one is what you would normally di. the 2nd one looks ok from the side but maybe a little janky from the end. either way.
Received 0 Votes
it seems to go a lot better if I stop trying to cut the post and simply score it and break it off....
I had no idea this stuff broke off at a score line so easily (using a t-bevel is a help too)....
Just wanted to say, Thanks...I'm going with option 1. I think I'd be in the fetal position right now without this forum...
Received 0 Votes
ok....one more quick question...almost done with the siding, but I think I'm going to have to redo the j channel along the gable.
I went with option 1 (a clean cut on the corner post angle and the j channel butted right up next to it....
I did not tab the j channel to fit in to the channel of the outside corner post and now I can see a very small opening at the very top of the outside corner post if I look into the area where the corner post meets the j channel that would lead into the inside of the corner post and possible the backside of the trim.
I'm not so worried about rain, because it would have to be raining up...but If I ever power wash it, I can see water being able to run behind the corner post.
Before I redo, I have to ask...
you would normally have a tab tucked in to the channel of the corner post...right?
You are being a little too OCD about this. Vinyl siding is in no way water proof, and water will obviously get behind it if you spray it with a power washer. That's what the WRB behind the siding is supposed to do... protect the sheathing/framing from getting wet, should water get behind the siding, which it will.
But to answer your question, no you would not ordinarily put a tab on the j-channel so that you can't "see up" into the space above the corner post. You can do it however you like if it helps you sleep at night, but it is not normally done that way.
