Sealing opening between metal flashing and sill plate
Need advise/expertise!
We have a huge gap between the metal flashing and the sill plate. What would be the best way to seal this gap? At its largest it is about an 2" wide and I am not sure what can be actually be done at the sill plate without causing any additional problem. Caulk with polyurethane and then spray foam and then parging mix? I can stick my hand in and feel the old tar paper thing they use to put between the foundation and the sill plate.
Also, what should I do around the rest of the house, the gap vary between non-existant and 1". Can I just caulk with polyurethane - but then its probably not going deep enough...
We need to seal out the bugs as we are going to spray foam our basement walls and rim joists and I do not want to create a nesting paradise (with easy access) for ants, etc.
Thanks so much for all your help and advice!!
-Catherine
-Catherine
Where there are large gaps, I'd be tempted to spray foam first, then a pass of polyurethane sealant over that. Foam backer rod is useful to avoid spending tons of money on polyurethane, along with helping to make it perform better.
Hi BridgeMan45,
Thanks for your response! Do you think there is any chance that we shouldn't be sealing the gap - could it be serving a purpose that I don't realise (i.e. water being able to come out if it gets behind the flashing)?
Thanks again for taking the time to respond,
-Cat
-Cat
Can't tell from the pix. Could you take a few from a bit farther away from the wider openings you're concerned about, to show more detail over a wider area? I've never heard of leaving gaps in place to enable water to escape, but then, I'm still learning.
P.S. Water should not be getting behind your flashing, if it's installed correctly.
